1 - 12 of 12 Posts
My friend has a 2001 Mercury Sable with the automatic climate control. He used to have a deck in the car and now he wants to go back to stock and cannot find the RCU connector that he cut off when he installed his deck. We found one at the junkyard but the wires are in different pins and are different colors. Does anyone has the wiring digigram for both the RCU and the audio harness in the trunk? I was going to use the RCU adapter we have and add/change wire placements.
I'm confused. He had electronic climate controls (EATC) and and aftermarket deck? That really isn't possible with out extensive modification. Do you mean the rotary climate dials?
any way. he cut the plug @ the RCU :eek: . There are 2 @ the RCU. one for the speakers the other for power and data. Which one was cut?
Or did he cut it at the Dash.
The diagram can be found in the Topic Finder. States for 2002 but covers 1996-2007.
http://www.taurusclub.com/wiki/index.php/2..._Wiring_Diagram
If you need more detail. Please let us know.
QUOTE (thesavo @ May 30 2009, 09:33 AM) index.php?act=findpost&pid=729000
If you need more detail. Please let us know.[/b]
No he has the EATC but he had the deck in his glovebox and "turned off" the stock radio/clock. And it was cut 3-4inches from the RCU. Not sure why haha. But thanks I'll check out the diagram.
I just talked to him and he said he has the RCU without the fins and the plug needed is the one all the way on the right.
Ok So You are looking for the pinout of C388c
Seen here circled ?[attachment=29682:RCU.JPG]
looking @ the connector from the harness
With the 2 little petrusions at the bottom.
This connector has pins 08-14, 21-26, I will send a pic soon.
Pin 14 is bottom left, moving in a line to the right to #8
Pin 26 is Top Left, moving in a line to the right to #21
[attachment=29684:c388c.GIF]
Pin 8 Ckt #372 Brown/Orange Audio System On (ASYSON)
Pin 9 Ckt #798 Light Green/Red CD Changer Left -
Pin 10 Ckt #799 Orange/Black CD Changer Right -
Pin 11 Ckt #724 Light Blue/Yellow Cell phone Audio -
Pin 12 Ckt #725 Pink Cell phone Audio +
Pin 13 Empty
Pin 14 Ckt #832 Light Blue/ Pink Audio Corporate Protocol A
Pin 21 Ckt #855 Violet CD Changer Left +
Pin 22 Ckt #856 Grey CD Changer Right +
Pin 23 Ckt #057 Black GROUND
Pin 24 Empty
Pin 25 Ckt #833 Tan Audio Corporate Protocol B
Pin 26 Empty
Good luck to you. If you need help de-pining the connector, let me know. I will do an experiment on mine.
which of those is the one mounted at the top center of the speakers out of curiosity?
Holy Thread Revival, Batman!
Thread revival or not...this exact post just saved my bacon.
Thanks thesavo...JoeAsheville
Pin 13 Empty
Pin 24 Empty
Pin 26 Empty
Would this be the same for an '05 Taurus? I had read on another thread that this connector could be used to connect a 12V Acc wire, but I'm not seeing anything there. (I'm trying to connect an iSimple that needs a ground and the above mentioned red wire.)
Thanks in advance --
Pin 13 Empty
Pin 24 Empty
Pin 26 Empty
1 - 12 of 12 Posts
