I replaced all my shocks/springs, ball joints, wheel bearings, sway bar links, control arms and subframe bushings. (aluminum) I am still getting a sort of loose rattling sound only when I go over bumps. Any ideas what this could be? Could it be the engine/transmission mounts? Could I have gotten a bad shock?
Thanks
I lesson i had learned the hard way is to check all the nuts and bolts after repair work. I had a nut back off after about 20 miles. ( my fault )
also take a look at the heat shield and dust shields.
