I know this is my first post here however I have had 2 SHO's and now i just bought another taurus for a winter car - so the 2011 stang can sit in the garage. I just picked this taurus up 3 days ago and was wondering if you guys can help me. My last SHO was a 94 so im hoping somethings changed since then.
The taurus i picked up is a 2001 Taurus SEL with the 24 valve duratec. It has 124,000 miles on it and recently just had a tune up- new plugs, wires etc.
My first question is
1. Start car in morning let it warm up- first 15 min of the drive to work - at stop lights it seems like the car engages to the tranny periodically like a surge. Imagine you have a spinning flywheel and you hit it for a split second so you interupt the spinning pattern- this is what it feels like. What would cause this (torque converter starting to engage prematurely) also after about 20-25 min it doesnt really do it anymore.
2. The auto lamps- when its in the auto lamp mode all th elights come on but the headlamps- however if i move to the headlight mode they come on. what would cause this?
3. The engine smells like its leaking oil and burning in the engine bay- what are the common places to check on this engine?
4. The steering- it pulls to the left a little and has a slight knotch from middle to going right. He said he had new ball joints- tie rods and alignment done?
The joys of owning a used car- any help would be appreciated and id like to do most of my repairs myself since i was able to do alot of it on my SHO's (timing belt, rack n pinion, fuel pump, A/C, water pump)
Also im Mike from Chicago IL and hope to keep my taurus running like new
Thanks guys
Thanks guys
