1 - 12 of 12 Posts
Ok, I've changed the plugs and wires and it was good for a couple of days then i was getting the tps code...fixed that. Now I'm getting random hesitation with no code or the cel will come on but then go back off...any ideas? I'm thinking fuel filter or gas cap
If the CEL came on, there will be a code set.
Gas cap problem (leak) will set and EVAP code, but will not effect the wa
y the car runs.
With that said, Checking fuel trims should help narrow the problem down.
I just checked the codes again...it's the same P0303 (#3 cylinder) and the accompanying P0316. These were the original 2 codes that prompted me to change the plugs and wires. The car did run fine for a couple of days after wards...any ideas?
This sounds identical to the issue I am having. I am currently pulling PO302 (Cylinder 2 Misfire) and a PO316 (Misfire Detected First 1,000 Revolutions) I have been goin bonkers tryin to figure this out. It also only happened after I changed the plugs and wires. I have tried swapping the old parts back on to no avail, replacing parts, etc.
Please if you find a solution let me know
P.S.- I've also have done just about all diag. tests you perform on it...nothin...everything checks out ok...WTF?
Yes, if you have an ohmmeter and a haynes or chiltons with the how-to and specs, you can run primary and secondary resistance tests. Or you can remove it and run it to autozone for them to test it. Only problem is the coil(s) can test in spec, yet still fail under load.
Coil on plug?
Move the coil to another cylinder and see if the code follows it. COP coils interchange.
Injector issues will toss a misfire code also, went through this on my GMC
1 - 12 of 12 Posts
