change/replace: motor oil, transmission fluid/filter, fuel filter, air filter.
inspect: brakes, accessory belt.
you could also rotate the tires, and decarbon the intake and clean fuel system if you wanted. I cant see it being too bad, though.
what exactly is a 60k for a non-sho taurus? I thought the 60k was a term for adjusting valve lash and replacing timing belt, plugs/wires, among other things. Isn't the first larger service for a vulcan and duratech at 100k?
