1 - 14 of 14 Posts
Was looking at my car the other day, and I saw this knob. Anyone know the function?
Edit: Car is a 1996 Sable with the Duratec 30
That is the fuel rail presser schrader valve. Just like a tire schrader valve.
That is the fuel rail presser schrader valve. Just like a tire schrader valve. [/b]
Yup.
Not a nob, just a cover.
<div class='quotemain'> That is the fuel rail presser schrader valve. Just like a tire schrader valve. [/b]
Yup.
So it pretty much is just in my head that when i adjust it, my car has faster throttle response?
Edit: It feels like I can turn it and adjust it
So, if I turn the knobs on my tires I can go faster too? [/b]
Yeah, and you will get 500mpg too. I was thinking the loosening of the nozzle might allow more air or less air in, but apparently not.
Also, better throttle response would not necessarily make it go faster
Unscrew it and look at what's under the valve stem cap.
Air in your fuel line = Bad. It will make the car stall/misfire all that good junk.
And better throttle response does not equal faster.
<div class='quotemain'> Unscrew it and look at what's under the valve stem cap. [/b]
I will once I get back in town tomorrow, not going to kill me is it? :unsure: :huh:
Nope. Unless you press the shrader, it will spray fuel if its still pressurized.
But it wont stop the engine from working, or blow you up. unless your soaked in gas.
Discussion Starter #12
But it wont stop the engine from working, or blow you up. unless your soaked in gas. [/b][/quote]
Alrite, thanks. I was not sure whether it was under high pressure or what.
The cap is just that - a cap. The pressure is held in by the schraeder valve, and it's exactly like the valve in your tire stem. Press the lil stem in the middle, and fuel will spray out, just like letting air out of your tires. As long as you don't press it, nothing will happen.
<div class='quotemain'> <div class='quotemain'> That is the fuel rail presser schrader valve. Just like a tire schrader valve. [/b]
Yup.
:rofl2: :rofl2: :rofl2: :rofl2: :rofl2:
Instant gold ! I say !!
1 - 14 of 14 Posts
