okay I put some gauges in my car.. White reverse gauges.. Installed them myself not really hard at all took me 30 min tops.. But here is my problem.. When its hot outside there is no problem but when it gets cooler around 55 to 60 degrees my speedo starts to lag.. like it's reading 35 while I'm going 45 and then I step on the gas it still stays at 35. But eventually it will run at the same speed when the cab warms up..
Do I just need to reapply the gauges or does it sound like I need new gauges
well I never took my gauges off my car... I just slide the gauge around them... This way I would not have to recalibrate my cluster... And I used crazy glue... I guess I will just go back and redo it whenever I have enough money to go to the store and by some spray tape... This time I will use a lot around the area of the center of the needle
