1 - 9 of 9 Posts
Hi, after runiing my hehr powerline alternator for almost a year, I have a problem or maybe I suposse is a problem, in winter I don't have a problem at all, the systema voltage work at 13.8 to 14.48 but, now, since here is summer, I'm starting to use A/C system and in the night in iddle the voltage is 12.5v (A/C + Headlight + 2 amplifier + headunit) but when I accelerate the engine to 1000RPM, the voltage return to 14.2V is this ok?
I need to upgrade the alternator or modding the alternator? I replaced the wire of the system (battery cables 1/0GA and alternator 1/0GA)
All I can tell you is every piece of charging system test equipment I've ever bought or borrowed requires the idle to be at 1500 RPM for an alternator stress test. I have no idea what warm/low idle output should be.
Are you having a battery discharge (dead battery) problem?
I think back in 88, Ford used the crappy, fire prone G2 alternator. If it is a G2 alt, it is likely a 65 amp unit.... kind of pathetic by todays standards. In other words, your voltage #s sound about typical. Alt output is suposed to be tested with the engine RPM at 2000.
I replaced the original alternator with a hehr powerline (series 24) alternator, this is rated with 150A (this alternator come with 12 diodes) this alternator use a external regulator but, I'm using the taurus original voltage regulator (a new one, but the original part) any suggestion how can I upgrade this alternator or if I replace the regulator with another model I can solve the problem?
my problem is, when the car run iddle the voltage decrease to 12.5 or lower, (in traffic this is a problem) sometimes the radio turn off for the low voltage, so, I need to recharge the battery
Sounds to me like the stereo system is the root of your problem here...I would read up on some custom stereo websites (I'm betting there are at least a few on the internetz :p ) and see what their solutions are for upgrading 80's era Ford systems.
Hi, today I have tested the system, and when I use lights + audio or another acccesory all work ok, but, when I use the A/C the iddle down to 650RPM and the problem with charge appear, but when I push the accelerator to 1000RPMthe voltage return to 14.2V
The Idle Air Controller should maintain the factory idle speed with the A?C engaged. If it isn't doing that it needs to be cleaned or replaced. I don't know what the idle speed is for that car though, probably 750 but I'm not sure. You really need to have a tach connected to set idle, because the original tachometer gauge probably isn't accurate any more.
The IAC will not open more if the problem is too much alternator load. AC yes, PS yes, because this is programmed into the PCM logic.
1 - 9 of 9 Posts
