1998 SHO shifting problems. Car only has 2nd gear when moving forward from dead stop, once car is at 10mph, I will shift into drive and trans will up-shift through all gears with no slipage even at full throttle. When coming to complete stop, trans will downshift through all gears, then I have to complete prossess again. Also, trans has no reverse. Change fluid, look good with no burnt smell. Could pull no codes at Advance Auto. I have read about upgrade kit, what should I be looking for or replacing. Thanks
So you have no first gear? Is the OD light flashing when it is giving you problems?
No, the only forward gear I have from a dead stop is 2nd, also cruise control and speedometer works all the time. Could it be shift selinoid.
