I have a couple of puddle lamp/heated mirrors off of an 02+ model I want to add to my car. Car already has heated mirrors from the factory. Since 00-01s are not prewired for puddle lamps, I am going to have to run two wires from the door to the interior of the car.
1.) Should I use the wiring I already have in for the footwell lights (goes to the Black/Light Blue in the passenger door kick panel wire bundle) and "daisychain" the puddle lamps into that? Or should I tap into the Light Green/Orange wiring for the Puddle lamps? Can I tap into a ground wire I already have for the footwell lights? Don't want to blow a fuse or anything. Or is there a better wire to use?
2.) When I run the wires from the door to the interior, is there some kind of wire covering/sheath that I can wrap around it or put the wires through to protect them from the elements and/or fraying with opening and closing of the door overtime? It is not going to be possible to use any wiring within the door on either side...no way to get the wires through.
Thanks.
Thanks.
