Injecting propane into a gasoline engine will throw off the A/F ratio, causing massive Bank 1 and 2 rich codes.
:werd: Unless you set your fuel trims to compensate for it, you'd just be rich. What are you trying to accomplish?
Not wanting to accomplish anything.I was just curious thats all. A friend of mine said that with the propane injection you'd probably blow the whole top of the engine apart.
.Propane powered vehicles (that are usually just modified gas engines) have been around over 50 years...>>LINK<<
I already know all that!What I want to know is it possible to make a propane injection kit.Exactly like a nitrous kit but only with propane.Would it work the same way as a nitrous kit would.
