so my car has a pioneer cd changer in it because it did not come with a cd player. about two weeks ago it started cutting in and out, and the songs would just start over randomly....weird.... and now for the past week it wont play anything and it just says Err 11.
i spoke to a local audio shop owner who i am friendly with and he said if you know all the discs are in correctly that its more than likely that the laser is bad and you need a whole new unit.....
anyone ever experienced this before?
i really dont want to spend a couple hundred bills on a cd changer so i hope theres a better alternative, is there any connections i can check?
mine was doing something similar to that it turned out my ground wire had come loose tightened the bolt and everything works fine now
Good idea there...check your grounds, and all other connections/wiring for the changer. Something could have come loose, etc.
just checked everything and its tight, could the cd changer really just be bad?
