1 - 2 of 2 Posts
94 Taurus "Ol' Ruby" the driver rear window goes down with the switch in the back, but rarely goes down with the master switch. It always goes up with both switches. You can hear it click when you hit the switch, and the window moves a tad, but it will not move it, MOST of the time, it worked great for the past 2 days, now it is doing it again...what is causing this???
Sounds like it may be a faulty master switch. But to be sure you'll have to remove the switch and try jumping the connector on the proper pins or test the switch.
1 - 2 of 2 Posts
