I am working on my alarm and I cant fiure out if my car has a...
Negative locking system
Positive locking system
Reverse polarity locking system.
Can anyone how has put an alarm on their car please help!!!!!
Discussion Starter · #2 ·
Here is what I have found from AUTOLOC
Remote Start
Accessory BLACK/L GREEN IGNITION SWITCH HARNESS
Tach Signal TAN/YELLOW AT POWERTRAIN CONTROL MODULE PASSIVE ANTI THEFT SYSTEM (PATS) BYPASS MODULE NEEDED (#BYTRAN or #BYTRAN2)
Ignition 2 RED/L BLUE IGNITION SWITCH HARNESS
Ignition 3 GRAY/YELLOW IGNITION SWITCH HARNESS
Rear Defrost D BLUE/ORANGE (-) AT REAR WINDOW DEFOGGER SWITCH
Brake Light RED/L GREEN (+) AT SWITCH ABOVE BRAKE PEDAL
Neutral Safety NOT GROUNDING TYPE - OEM SWITCH OPENS STARTER CIRCUIT
Reverse Light BLACK/PINK (+) AT SWITCH ON TRANSMISSION
I think there should be a sticky made from this, please.
I have to hook up the triggers for the alarm does anyone know what wires to use?
Dome Lights BLACK/L BLUE (+) EITHER KICK PANEL
THis is the wire that is the trigger for the alarm.
I take it no one has really ever put in there own alarm?
