Evening cats,
I've been looking everywhere and thought I might ask you all.
I'm trying to replace the power antenna mast for my 1996 Mercury Sable Wagon. I was able to get all the external bolts and coverings off, but was still unable to pull the mast from the car. The instructions that came with the replacement antenna said it should just be that easy: pull the old one out, slide the new one back in.
I have a feeling I'm going to need to get inside the antenna assembly from the interior, so I removed the panel, the spare tire, the jack, etc. and got a flashlight in there to check it out but I can't get close enough to actually work with it.
Is there an access panel in the metal I'm not seeing? Which screws or bolts should I remove to separate the interior steel from the hull? There are no diagrams for this anywhere that I can see.
Thanks for all your help.
