1 - 16 of 16 Posts
If you have had a spring break on your Taurus, please post what year,
front or rear, where they broke, and if it punctured a tire.
i had a rear spring break on the lowest coil no tire damage. car is a 2000 sable im not sure when it broke but i think it was not long after i got it so probably in 07
i even still have that spring haha
front left spring broke on my 02 in 07 or 08 cant remember, ruined the tire too.
Both of my rear springs on my 01 broke in 08. No tire damage, but the broken spring on one side was within 1/4 inch of my tire.
60K miles! Never should have happened.
Front driver's spring on my '02 in 3/2008 at about 60K broke and destroyed the tire. Not sure where the spring broke.
Both rears on the same '02 in early 2010 at ~80K-85K, somewhere near the top or bottom as only a small part of the coil broke off. No other known damage from the rears.
In all three instances the car was parked when the springs broke.
Left Front Spring Broke 4 days ago, I was 14 days outside of the 10 year warranty on the spring and Ford would not budge on replacing them for free, very frustrating.
2 - 1997 SHO's. Both cars were rear coil spring failure, near the top, due to rust. Neither blew out a tire.
Seen 2 1999 SHO's that BOTH blew out front tires, without warning. Both cars were parked at the time so luckily nobody was hurt.
Ford fixed both under a recall.
96 Sable LS - LR spring, small piece broke at the top of the spring, mileage prior to 67K, tire not affected. Replaced with set of rear springs from NAPA.
2000 Taurus broke the drivers front at about 70K miles. No tire damage and the Ford dealer picked it up on a flat bed trailer at my house and replaced both front springs and installed shields. Passenger rear broke just recently at 150K miles with no damage to tire. I replaced the rears with cargo coils and sensatrac struts so hopefuly won't break again.
01 Taurus:
Passenger rear in 2008, 38,000 miles - ruined new michelin tire
drivers front in 2010, 60,000 miles - covered by ford warranty
2001 SEL 80,000ish kilometers Both rear springs broke about 6 months apart in 08 No tire damage Recently noticed front springs are starting to rust up pretty good.
1 - 16 of 16 Posts
