No need to pull the motor to get the Y pipe off. But if you do then it is easier to drop the whole drivetrain out still on the subframe.
Plugged cats in the end wouldn't likely be the problem, but they could participate. Any misfire, from low compression or something is a death sentence to cats, which would then plug up, adding to your problems. But the root cause would be a misfire.
