1 - 15 of 15 Posts
Hi all,
Please bear with me, as I'm pretty dumb when it comes to cars. You guys are my last resort! I suspect that I have a vacuum leak somewhere along the intake line (getting two error codes that indicate a lean condition), so I pulled off the hose that comes out of the air filter housing and found two extremely small pinholes.
I went to order this hose online (called the "outlet tube" on the site that I was ordering from), but I got an email back saying that the part would only fit engines up to 2003. They suggested I purchase the ENTIRE air cleaning assembly for $250, which is ridiculous IMO.
This is the ribbed, accordion shaped hose that runs from the air filter into the engine (not sure what that part of the engine is, I told you I'm pretty dumb).
I don't have the error codes that it has been spitting out, but can post them when I get home from work. I'd REALLY love to avoid taking it to the shop over this.
Symptoms
-Very rough idle at cold start
-Idle is worse in cold weather
-Engine runs smooth at cruising speed
-Definite tach bouncing at idle, tends to lessen as engine warms up
It has died once, during a turn in which i was turning sharply and braking. If I had to guess, the engine ran lean, and the extra RPMs that were lost during the turn killed it. Really freaked me out.
I have never replaced anything in this engine, it's got 58k on it.
Thank you so much in advance guys! :x:
edit: part number 6 on this diagram
Forgot to add, if you think it could be something other than the hose, please say so. I've heard of people solving this issue by replacing the UIM gaskets, PCV/PCV line, and O2 sensor, but I hate to just start throwing money into it.
Symptoms are similar to mine.... I shall check my hose :angry:
Wow that sounds just like mine as well. I have replaced just about everything else and I checked mine and it seems ok. The hose you need is it the hose from the Mass Air Flow to the Throttle body? If so a junkyard is your best bet and it shouldnt be more than 10 bucks or so. I have a 2005 vulcan. Lets see if anyone else can see what the problem may be since I am having the same issue.
If the 2 pinhols are really small, just patch them up with some sensor safe RTV and be done with it.
The way to test is to spray starter fluid on suspected areas with the car idling. The engine will stutter if you spray on a vacuum leak.
I'll need to get some starting fluid. BullGeek and I sprayed a few places with carb cleaner or something similar and no dice...
<div class='quotemain'>
I havent replaced either as of yet since both seem to be in excellent shape. I checked them again yesterday, but since the PCV valve is cheap I may go ahead and get it.
junkyarddog.com is a great website. If you cant find it there got to ebaymotors and craigslist to see if anyone is parting out a car simialr to yours.
When you figure out how to remove that PCV, holla back.
Discussion Starter #13
Thinking it might not be the hose. Tried removing the PCV by hand, but couldn't get it out of the block. I guess the question is, could a bad fuel filter or fuel pump cause a lean code to pop? The more I research fuel filters, the more it's sounding like the issue.
Lean codes suck, this much I know.
Doubt its the fuel filter. I have the same codes and I just replaced mine.
I am thinking it might be the EGR or the idel air control valve as well.
Discussion Starter #15
The only reason I'm thinking it might be fuel related is that I've got a definite whine/whistle coming from the rear half of the undercarriage...which seems to be a symptom of fuel pumps that aren't long for this world.
1 - 15 of 15 Posts
