Hey all,
I finally got around to checking out why my brake and abs light didn't work. I removed the instrument cluster as the service manual said, and checked the bulbs. They both were good, so I reconnected it to see if it was a problem with the contacts. Then when I turned the ignition to run, My fuel gauge went to above full. :huh::huh: My fuel was just below half prior to disconnecting the cluster. Somebody please help. I hope I didn't bust something expensive. Thanks in advance.
Discussion Starter · #2 ·
nvm i think its fixed now. I disconnected both the battery and the cluster and reconnected them. now the fuel gauge went back to about half. thanks anyways and cheers!
