Hi everyone! I don't post here much, I'm mostly on Delphi and SuperHighOutput.com, but I'm working on a conversion kit that will be available to Gen2 SHO and Sable drivers, and so it is relevant to you as well. I'm posting here because I need some feedback before making a decision on the final design.
The issue is what to do about the front park/turn signal. I have several options to add turn signals to the covers. I am looking for opinions so I can decide what to produce.
The first option is to convert one's fishtank assemblies (SHO only) into turn signals. I have already done this with mine, and they work great, and would probably come pretty close to passing DOT lighting requirements. However, although they are very visible (more so than the oem lamps IMO due to their position being well away from the low beam headlamp), they are not stamped as being a DOT approved park/turn signal. Here's a link to my page on the conversion:
http://www.angelfire.com/home/SH0ckforce/P...gnal/index.html
For those of you that have not yet seen my work, here's a link to my write up on the first design:
http://www.angelfire.com/home/SH0ckforce/Projects/index.html
The second option would be to use other turn signal lamp assemblies. Here's a link to the options I'm considering:
http://www.angelfire.com/home/SH0ckforce/P...cts/Index3.html
If you are interested in the kits, let me know what your preference would be. I need to decide what lamps to use and order them so I can incoporate them into the design.
Thanks,
David
Thanks,
David
