1 - 1 of 1 Posts
All stages come as a complete kit including disc, pressure plate,
throwout bearing, pilot bearing (when applicable), and alignment tool.
Assembled in the USA
FX100: Street Performance Clutch Kit
The FX100 System uses the Power Plus I Pressure Plate with a custom heavy-duty Steel Back Organic friction disc. This clutch is engineered for heavy-duty street use. It is specifically designed for extended wear and additional clamping force for the enthusiast who has added an exhaust system, an intake system, up to 50hp NO2 upgrade, or other non-forced induction external bolt-ons. It features only slightly increased pedal pressure, longer life than stock, and normal clutch feel during engagement and disengagement for a very smooth operation.
FX100 Clutch Kit
Taurus - 86~88 - 3.0L / 3.8 6Cyl - HD Plate - Dampened hub steel-backed organic lined disc
Taurus - 91~96 - 3.0L (SHO) 6Cyl - HD Plate - Dampened hub steel-backed organic lined disc
Taurus - 94~96 - 3.4L 6Cyl - HD Plate - Dampened hub steel-backed organic lined disc
FX300: Street/Race Performance Clutch Kit
The FX300 System uses the Power Plus I Pressure Plate with a Steel Back Segmented Kevlar disc. This clutch is designed for the ultimate street enthusiast or weekend racer running a normally aspirated car equipped with cylinder head work and/or hotter cam(s), or with medium-boost turbo or super-charger, or up to 100hp NO2. The FX300 features only slightly increased pedal pressure, long life disc and positive engagement.
FX300 Clutch Kit
Taurus - 91~96 - 3.0L (SHO) 6Cyl - Double diaphragm pressure plate - Dampened hub segmented Kevlar disc
Taurus - 94~96 - 3.4L 6Cyl - Double diaphragm pressure plate - Dampened hub segmented Kevlar disc
Lightweight Flywheels
Reduced mass equals increased acceleration. Reduces turbo “lag” in turbo-charged engines. Increased supercharger efficiency due to less drag on the crank. Improved mid-range torque in normally aspirated engines. Two-piece unit featuring a high carbon steel replaceable friction surface. SFI Certified. Rev Quick - Typically 50% Lighter and Stronger than OEM
Taurus - 91~96 - 3.0L (SHO) 6Cyl - ALUM - 12lbs
Taurus - 94~96 - 3.4L 6Cyl - ALUM - 12lbs
GO TO NOPI/CLUTCH MASTERS Catalog for model specific web prices and details
Contact the salesmen below or PM me for our best deal on CLUTCH MASTERS Clutch & Flywheel kits
1 - 1 of 1 Posts
