I recently found a hole in what I believe is my PCV elbow. While changing it, I realized that the piece closest to the front of the car... the PCV Valve... idk... well anyway, it swivels. I can't see down there for **** so I was wondering if maybe it's in some kind of grommet and that's why it swivels, or if it's supposed to or if it should be stationary? I do still hear a small vacuum leak is why i ask. this little picture i found on google is exactly the elbow i changed, with the hole in exactly the same spot.
Here's the way it works on the 2000. I thought it was the same on all Duratecs
Mike
B)
If you're talking about the plastic elbow right on top of the pcv valve, then yes, over time, that will get a bit loose and spin on the valve. Sometimes the valve itself can turn in the grommet as well. If you're worried about a leak, change the valve and the grommet.
