1 - 2 of 2 Posts
While the intake of my 2005 DOHC was off for a plug and coil change I decided to change the PCV valve. I compressed the hose clamp with long nose pliers and as I pulled the clamp off the whole PCV assembly came out!
The plastic housing the PCV valve is seated in has 4 lugs, well it's supposed to but mine only has 2. My problem is I can't find any listing for the housing on it's own, just the PCV valve, don't even know what it's called.
Can anyone identify the housing or if there is an alternative such as a rubber grommet to replace it?
From what I can find, the valve twists into that connection. I would try to reuse the one you have if you can. I tried looking for the intake itself to see if that connection comes with a new one, and I couldn't find the intake either. Just gasket sets. You may have to search your local jy.
1 - 2 of 2 Posts
