On a 2014 ford taurus limited. I just got a 320 HO alternator that's internally regulated and I'm bypassing the PCM. Is there any way to trick the pcm into sensing an alternator so I don't get a battery light?
Black tape over the light and use a plug in volt meter in the power port. Dual purpose, good information too.On a 2014 ford taurus limited. I just got a 320 HO alternator that's internally regulated and I'm bypassing the PCM. Is there any way to trick the pcm into sensing an alternator so I don't get a battery light?
I'm trying to avoid the light coming onBlack tape over the light and use a plug in volt meter in the power port. Dual purpose, good information too.
I've tried to no avail. Just really trying to avoid a battery light.Do an internet search because I believe I have seen a wiring harness to accomplish what you want.
Look at this product. Ford PCM controller adjustable voltage with battery light deleteI've tried to no avail. Just really trying to avoid a battery light.
Seems like this person has done it multiple times i the last day and should be banned.^^^^ GO AWAY TROLL!! Keep copying and pasting other members replys and you will be banned from this site!
GET A LIFE!
Pic of G-4 Bulls, '02 and later. There is an "always hot" wire that activates the reg. Trim volts is shown it can be cut. The There is a signal wire for the light 6V when not on, 0.5V makes the bulb light. PCM manages that power to the bulb.
Pic is for '03, other years will be different.
To eliminate the light, if you have the diagram as in post #4, DOHC you can cut the wire at the PCM LG/RD. Light is out of the circuit.Pic of G-4 Bulls, '02 and later. There is an "always hot" wire that activates the reg. Trim volts is shown it can be cut. The There is a signal wire for the light 6V when not on, 0.5V makes the bulb light. PCM manages that power to the bulb.
