New member, great forum all. I have an 02 Merc Sable Wagon 3.0 U code. I was having a PATS issue with the car. I took it to dealer as last resort. They called and initially said the ignition cylinder and transceiver was bad. $725.00. I pushed back and asked why they suggested replacing the cylinder when it operated fine. The guy called me back a few minutes later and said, it does work fine, it was just the transceiver bad. New costs 525.00. So they replace the transceiver and he calls me back the next day and says, oddly enough the PCM is also bad and there was no way to tell it was bad until after the transceiver was replaced.
Now to me that sounds like a mis diagnosed problem the first time and they are trying to hook me for both. So my question is this, is it true that you cannot diagnose a PATS prob with the PCM if the transceiver in not functioning correctly. It seems like the chances of both of them going bad at the exact same time are slim.
Thanks guys!
Thanks guys!
