1 - 14 of 14 Posts
i may be wrong but it appears to be part of the brake bias system..
Proportioning valve. It adjusts the brake bias dependant on weight.
what year was that put in? my sable doesnt have it... so i would assume 2001?
what year was that put in? my sable doesnt have it... so i would assume 2001? [/b]
Actually, it was an earlier thing. I didnt think that G4s had them at all. Mine doesnt.
<div class='quotemain'> what year was that put in? my sable doesnt have it... so i would assume 2001? [/b]
I thought I remember Mark saying that non-ABS G4s have that valve...
I thought I remember Mark saying that non-ABS G4s have that valve... [/b][/quote]
Ahh, makes sense. I don't see the abs sensor wire there or the clips that hold it on the control arm.
oh ok i see i guess i never would have even thought of that
Just to confirm....my G4 is in fact a 2001 (LX) with no ABS.
Proportioning valve. Interesting. Thanks for all the replies!
what year was that put in? my sable doesnt have it... so i would assume 2001?[/b]
uh, "put in" in 1986
for the record, the 93 SHO in the drive, has one of these AND abs.
i didnt know... my sable is the first of my taurus' that i have ever had to do brake work on
To answer your question... this is a brake bias mechanism for non ABS automobiles. It adjusts the braking power of the rear based upon weight,,, hence the lower the car sits the more rear braking power will be applied.
All 5 of my gen3 tec sedans have the rear load-sensing prop. valve. Abs, non-abs, disc or drum, doesn't matter. Iirc, station wagons have a stationary prop. valve mounted up front under the master cylinder/booster area on firewall.
Hummm.... proportioning valve.
I had to replace one of the brake lines on my 97 Taurus the other day and was wondering what it was.
Mine seems to be in poor condition due to road salt and corrosion. There's a fair amount of rust on the spring & shaft going into the block. I really ought to replace it while i'm changing out the rear hoses & brake lines this summer.
Does anyone know if it's a dealer part or how to set the adjustment after it's been replaced ?
Thanks
1 - 14 of 14 Posts
