Rats. I have a parasitic current going on. With everything shut off, no lights on, no lights on in the glove compartment ands trunk I used my multi meter in series between the negative terminal and ground to determine I have an almost a 5 amp drain. I found it is going through fuse 33, which powers the hazard lights, cluster, ICP, and temp control panel. When I pull fuse 33, the drain goes back to 0.015 A, and when I change to scale to mA the drain turns to be 3 mA. There have been a few posts on the forum about a drain through fuse 33 (15 amp fuse), but no one reported a fix.
Has anyone been able to fix the problem? Here’s a description of what fuse 13 does and the readings off my multi meter. Thanks. Spock.
