G
I pulled the thermostat housing off one of my spare SHO 3.0s and decided to paint it. but first all the casting imperfections must be taken care of..
The Before Picture.. after being cleaned.
http://www.supermotors.org/getfile.php?id=131671&toggle=fullsize&f=.jpg' alt='' width='1280' height='960' class='attach' />[/url]
1st casting mark ground off
[url=http://www.supermotors.org/getfile.php?id=131672&toggle=fullsize&f=.jpg][img]http://www.supermotors.org/getfile.php?id=131672&toggle=fullsize&f=.jpg' alt='' width='1280' height='960' class='attach' />[/url]
2nd casting mark ground off
[url=http://www.supermotors.org/getfile.php?id=131673&toggle=fullsize&f=.jpg][img]http://www.supermotors.org/getfile.php?id=131673&toggle=fullsize&f=.jpg' alt='' width='1280' height='960' class='attach' />[/url]
1st casting line.. "before"
[url=http://www.supermotors.org/getfile.php?id=131674&toggle=fullsize&f=.jpg][img]http://www.supermotors.org/getfile.php?id=131674&toggle=fullsize&f=.jpg' alt='' width='1280' height='960' class='attach' />[/url]
1st casting line.. "after"
[url=http://www.supermotors.org/getfile.php?id=131675&toggle=fullsize&f=.jpg][img]http://www.supermotors.org/getfile.php?id=131675&toggle=fullsize&f=.jpg' alt='' width='1280' height='960' class='attach' />[/url]
2nd casting line.. "before"
[url=http://www.supermotors.org/getfile.php?id=131676&toggle=fullsize&f=.jpg][img]http://www.supermotors.org/getfile.php?id=131676&toggle=fullsize&f=.jpg' alt='' width='1280' height='960' class='attach' />[/url]
2nd casting line.. "after"
[url=http://www.supermotors.org/getfile.php?id=131677&toggle=fullsize&f=.jpg][img]http://www.supermotors.org/getfile.php?id=131677&toggle=fullsize&f=.jpg' alt='' width='1280' height='960' class='attach' />[/url]
3rd casting mark ground off
[url=http://www.supermotors.org/getfile.php?id=131678&toggle=fullsize&f=.jpg][img]http://www.supermotors.org/getfile.php?id=131678&toggle=fullsize&f=.jpg' alt='' width='1280' height='960' class='attach' />[/url]
And the grinding is finished..
[url=http://www.supermotors.org/getfile.php?id=131679&toggle=fullsize&f=.jpg][img]http://www.supermotors.org/getfile.php?id=131679&toggle=fullsize&f=.jpg' alt='' width='1280' height='960' class='attach' />[/url]
After a nice sanding some "Heavy-Duty Auto-Filler" is applied
[url=http://www.supermotors.org/getfile.php?id=131680&toggle=fullsize&f=.jpg][img]http://www.supermotors.org/getfile.php?id=131680&toggle=fullsize&f=.jpg' alt='' width='960' height='1280' class='attach' />[/url]
After sanding the filler, 5 coats of specialty 1200 degree engine paint were applied.
[url=http://www.supermotors.org/getfile.php?id=131681&toggle=fullsize&f=.jpg][img]http://www.supermotors.org/getfile.php?id=131681&toggle=fullsize&f=.jpg' alt='' width='1280' height='960' class='attach' />[/url]
A few rusty brackets get some much needed sanding and paint.
[url=http://www.supermotors.org/getfile.php?id=131683&toggle=fullsize&f=.jpg][img]http://www.supermotors.org/getfile.php?id=131683&toggle=fullsize&f=.jpg' alt='' width='1280' height='960' class='attach' />[/url]
installed
[url=http://www.supermotors.org/getfile.php?id=131684&toggle=fullsize&f=.jpg][img]http://www.supermotors.org/getfile.php?id=131684&toggle=fullsize&f=.jpg' alt='' width='1280' height='960' class='attach' />[/url]
installed
[url=http://www.supermotors.org/getfile.php?id=131686&toggle=fullsize&f=.jpg][img]http://www.supermotors.org/getfile.php?id=131686&toggle=fullsize&f=.jpg' alt='' width='1280' height='960' class='attach' />[/url]
installed
[url=http://www.supermotors.org/getfile.php?id=131687&toggle=fullsize&f=.jpg][img]http://www.supermotors.org/getfile.php?id=131687&toggle=fullsize&f=.jpg' alt='' width='1280' height='960' class='attach' />[/url]
[i]not[/i] installed but finished.
[url=http://www.supermotors.org/getfile.php?id=131682&toggle=fullsize&f=.jpg][img]http://www.supermotors.org/getfile.php?id=131682&toggle=fullsize&f=.jpg' alt='' width='1280' height='960' class='attach' />[/url]
When I finally get around to installed the $75 thermostat I bought from Ford (3 months ago) for my 3.2 I'll install the newly painted thermostat housing.
G
Give us the details. What exactly did you use? Is it in a can or do you spray it on with a gun? Was the black VHT or something else?
Why was the thermostat $75?
spray cans...
it was $75 because it's an SHO only part and I got it from Ford.
**edit.. and it's adjustable.. heh.. an Adjustable Thermostat!
