For some reason the two tires on the back are P215 but the front ones are P225. Could that cause handling problems or anything?
Should be fine, as long as the tires on the left and right are the same and the psi are same. The rims the same?
sounds like you've got a good race setup for auto-x.... wider tires in front to help minimize understeer so you don't plow through the cones B)
Yeah front two are the same, and the back two are the same to each other. Yeah same psi and stock size rims.
LMFAO, I don't think I would want to put my Taurus through that.
