Hey guys,
Got an '03 SES with the 24V engine and Saturday it started hesitating. I read the threads about taking the AIC off and cleaning it,,,that didn't do me any good. I'll stop and pick one up after work. It's seems like everything I've read here leads me to believe that a new part may or may not fix the issue. Have any of you guys that have actually experienced this problem found it to be something other than the AIC? I haven't found anything here that was a definitive solution for this. Any help is appreciated.
^ If the iac is truly the problem, oft times cleaning wont do it. You were right in trying, because the lil bugger is quite pricey.
Ok, so I cleaned it out again, disconnected the battery to reset everything and then cleared the codes. All I'm getting now is the P0303...I guess I'll be changing some spark plugs...
