No problem! The crank sensor is located on the driver's side of the engine, under the upper intake manifold. It's a little hard to see because of the wiring harness. I'll attempt to get you to it though. Follow the upper radiator hose to the thermostat housing, which is mounted on the lower intake. Directly behind that, mounted in the engine block, is a black plastic piece, about 2" diameter, with an electrical connection on it. It is mounted to the syncronizer shaft, which looks like half a distributor shaft. The sensor is the black plastic part. Remove the electrical connector, and the two screws holding the sensor on to the shaft, and remove it. Replace the sensor and reinstall the screws and the connector. Don't remove the whole shaft, as you need a tool to time it afterwards. If you need any help, or pictures, let me know and I'll take some for you.
