I hope that someone can shed some light on this situation I find myself in with my 2003 Taurus, 3.0 Vulcan engine. 133500miles.
About 3 months ago I put in new spark plugs, wires, and a coil pack and the car was running great.
1 Week ago I did something I rarely, if ever do. I floored it while getting on the highway, got up to 60 or so, leveled out and drove for a while. I stopped at a 7-11 and when I restarted had a blinking check engine light. I pulled the code out as P0302. A misfire on 2. I pulled the battery and reset the computer and the check engine is/was off but the car still was idling rough. I came to this board to see if I could find any advice for what to check. The light will remain out UNTIL I hit the highway again, then it will return, so something is triggering it there. But the idle remains rough, and you can feel a vibration when accelerating, even a little.
While parked and turned off I have pulled the IAC and it was fouled a bit, and at idle when I disconnect the IAC connector, the engine does die, so I think it is working OK. I did not clean it per Ford warning. I am checking for possible vacuum leaks but can't find or hear anything. The PVC elbow does have a few small cracks (I ordered a replacement.) I also cleaned the MAF (with MAF cleaner)
Now, I go back to the heavy foot I had last Saturday as I am not a jackrabbit driver normally and I think the excessive acceleration might have put some heaver than normal vacuum or stress on a part that was marginal. The question is, what part?
I am wondering if it might be as simple as a clogged fuel filter. (going to get it changed for good measure anyway)
Any thoughts would be appreciated.
Are you ruling out spark plug because you put a new one in a few months back? It is an easy check though.
Yes, only because the car was running great for 3 months since I replaced the plugs and wires. Over the last 48 hours, I"ve gotten two different misfire codes, a 301 and a 302. Only when I am on the highway. Local driving doesn't seem to trigger the codes (even though idle remains rougher than 'normal"
Thank you for your response.
Engine vacuum is highest at idle and decel. At WOT the entire intake system is at virtually atmospheric pressure.
Jeff, that is very interesting. I still can't explain why then it happens on the highway. Or perhaps after I am at speed, when I lay off the gas, the vacuum kicks up. I FEEL like it is a vacuum leak somewhere (again, a gut feeling only because of the way it all happened)-- I feel that a line may have cracked under some stress. Would the IAC have any effect at road speed or only at idle. I pulled the wiring off the IAC while at idle and the engine died. That is the only test that I know of. (other than popping for 60 bucks for a new one)-- I tried the tap test, with no change of idle.
Thanks for you input.
after reading your input, I decided to try a test. I took the car onto the highway today (no codes but rough idle)--stepped on it hard to get up to 60mph, and stayed there for about 4 mins I then took my foot off the gas and just coasted. The car then gave me a blinking check engine light. The code was P0302 (misfire on 2)--
Not sure if any of that helps, but I hope someone can suggest a next test to try. Thanks.
Vac leaks often show up the most at idle and decel when engine vac is at the maximum.
Discussion Starter · #8 ·
well, I'm fixed
I want to thank everyone for their input. I was wrong in assuming it could not be a plug. We changed the plug in #2 and all is well with the world. Remember, I put in new plugs just 4 months ago. So problem was just that. Sometimes the obvious IS the answer.
Thanks again
