'97 vulcan, 209k miles
Several weeks ago was getting both P0171 & P0174, now only P0171. Rough idle, sputtering, occasional misfire and a stumbling sound.
Leak detector flow meter indicated a large leak.
In the past few days, I replaced gaskets for EGR, IACV, LIM, UIM, TB & valve covers. Rubber hoses have also been replaced. Hard plastic lines appear to be fine. After replacing gaskets and removing IAC, EGR and closing off various hoses the leak detector flow meter still indicates a large leak.
Fuel filter & pump also replaced due to weak pressure & inaccurate gauge.
Exhaust system smoke test - looking under car and finding no leak other than muffler.
Connected detector directly to brake booster hose - no leaks found - psi was building up.
Owned this car for nearly 12 years and the past couple of weeks I've have had so many problems happen at once. Don't know what else to do.
I have read many many postings here and articles & videos elsewhere regarding P0171.
Hope to hear ideas or recommendations from the great people here.
Ray
Ray
