Ok ,
Here is the problems i am having , and before any says take it to a mechanic well i took it to 3 and could not get an answer.
So while sitting still the car hiccups and if i mash the throttle it hiccups real bad with a small backfire sound from under the hood, What could this be.
Second , when i got to work this morning i noticed a little smoke coming from under the hood , i looked and noticed that under the wire harness cover in the middle of the intake down on the block there is a puddle of oil that was burning , i know i wasnt there before, what could this be.
I have no check engine light coming on.
1996 Taurus LX
Duratec 24v DOHC
Have you had any recent engine work?? Tune-up, gaskets, intake removal/cleaning?? Puddle of oil is obviously a leak or seepage, find that and repair. "Hiccup" could be an IMRC/intake /vacuum leak, and part of the oil leak.
I found the Hiccup , I took my Ignition Coil off and looked at the bottom of it and it was missing a chunk of the Plastic body. I installed a new BWD Coil and took the valve covers off and think i found my leak.
Car runs great and i hope the little bit of smoke i see is just the old oil burning off
You took it to 3 mechanics and none of them found a bad coil pack? Are they all retarded? I'd suggest you NEVER go to any of them again if they're that stupid that they can't find a coil pack with a chunk missing when you have a misfire.
