1 - 2 of 2 Posts
Have noticed a lot of buzz about problems with the heaters and the answer seems to always get around to the door actuator. Would this be the cause of similar problem with the AC. 2004 SEL has climate control and for a number of years, cools just fine for about an hour. Then starts petering out. I always decribed to many technicians that is sounded as though a "door" shut and the blower speeds up to overcome it.
This is when the cool air stops. As a side note, I may have noticed a similar occurance this past winter with the heat, same set of conditions, same result in the opposite direction. Coincedence or are these two conditions related? i.e. A/C heater blend door actuator??
When the blend door shuts, try the AC auto diagnosis procedure -- push Off and floor simultaneously, then Auto. It may get the door unstuck.
1 - 2 of 2 Posts
