You may want to replace the Multi-Function switch, but before you do, try cleaning it.
I did try cleaning as stated in my post.
Thanks.well then time for a replacement... those posts have removal instructions as well. But there is a write up to Remove and Repair specifically: http://www.taurusclub.com/forum/index.php?showtopic=64176[/b]
Yep, it was greasy. I cleaned it w/swab and alcohol. Same deal. I did not re-lube it.Did you take the cap off the end of the stalk?[/b]
