When you changed the Distributor did you replace the T.F.I. module too?The engine at idles like to backfire[/b]
Dido with the compression. Might be time for the snake oil (Engine Restorer)If you find out you have low compression. This stuff will work if the wrings are just stuck with carbon from using dino oil. Its cheap and worth a shot.Originally posted by JCC@Jan 19 2004, 11:47 AM
This could be the problem. With marginal compression rings the engine would have very little compression when cold, but when warm with an oil film the compression goes up considerably. Or a worn camshaft and lifters that are bled down when cold there by not opening the valves until pumped up with oil.
