Anyone know where I can find a place to tape into the oil pressure reading for a 3.8L? I think there's an oil pressure switch somewhere, but I'm not sure what to look for.
Thanks!
If im not mistaking i think the right wire will have a red white wire going too the sensor on the block they are usually by the oil filter and only have one wire going to it. Mines a 3.0 and it is by the distributor.
The oil pressure switch is usually by the oil filter. When you find it take it out and put in a tee fitting so you can put in your after market sender and keep the idiot light or gauge.
Thanks a lot guys, I think I remember seeing that line when I was changing the oil last month. Didn't know that was it
