well the SHO started stumbling a little and lost a good deal of power in the midrange, pulled the plug wire and yup, i got oil in my plugwells. i know that i need to replace the valve cover gaskets and plug well seals. i heard that there is a quick fix involving carb cleaner. (i intend on replacing the gaskets, just want to make this thing run better till i get around to it) and also while i have the intake off is there anything else i should do under there? i was thinking check/readjust valve lash, but the previous owner had it done about 15K ago, would there be any benefir to doing it again now?
thanks
matt
thanks
matt
