what could be causing oil in the intake? could it be a bad PCV valve? or could it be as bad as ring blow by. its a decent amount of oil. its all the way to the rubber tubing that is between the intake manifold and the MAF. when u push on the gas it seems to be running ok, just a bit of smoke out the tailpipe but it will not stay at idle it wont run under 1k rpm's
