I changed the oil for the second time on my car. A 13mm socket and the drain bolt was off, and 5.5 quarts of fluid was put back in.
A little over 5K and the oil was definitely darker than the newer stuff (Mobil1 10W-30 synthetic). When it came time to remove the oil filter (Motorcraft FL820S), super easy this time since I did the oil change last time and didn't superman it on. I did run into something that has me wondering...
Last time I stabbed the oil filter, to get enough torque to remove it with a flathead screw driver. The holes created by the screw driver drained the oil from the filter before removal. This time, when i started loosening it, after it was 3/4's of the way off, oil started coming out and it splattered in many places. I used brake cleaner to remove it off the side of the engine block, exhaust tubing, subframe, cat, etc.
Is there some kind of shield or method that should be used to keep the oil from splattering? Or any other suggestions?
Thanks.
[edit]I had the car up on ramps when doing this[/edit]
Thanks.
