I have a Gen 2 GL (3.0) and I want to change my oil. I'm pretty sure I should use 5w-30, but I'm not sure what the difference between that and 10w-30 or 40 would be..? Anyone explain the differences to me? Thanks.
ure suppose to use 5w30...its what ive been using on my 95 Gl with the vulcan 3.0 litre in it..
5w30 will work better in temps bellow 0 deg. F, 10w30 will work ok until 0 deg. F., 10w40 will be ok at the same temps as 10w30 but is thicker and you might loose some mpg.
Typical answer would be to use a fully synthetic 5w-30. I personally use synthetic 5w20, 0w30, 5w30 or 10w30 whatever is on hand. using fully synthetic oil will also give you a couple mpg more.
Ford recomended 5w30 for all their cars for a long time, recently they started to recommend 5w20, some people think this is to thin and provides less protection so many stick with 5w30.
I think a 3.0l takes 4 quarts of oil. Put 4 quarts in and then check it on the dipstick a few minutes later and add some if the need be, I usualy fill it til its on the top of the hash marks.
