was driving around enjoying the weather...my rear passenger side pad has been grinding for about a week. (My rear rotors are shot, and the one pad always wears down fast, plus the 1 pin in each of the brakets are jeammed)..anyways I was going into reverse and the rear wheel seized up, and then broke loose when I went forward again. Well the car was fine for a while...then I noticed the grinding wasnt there...so I thought maybe the bad fell off...but usually I would be greated by the nice screech....however I am not...I looked and the pad looks like its halfway on, however when I go to stop I have no pressure in the break pedal at all, and then when i put it to the floor you can feel the e-brake kick in. So do y'all think its just the fact the pad aint there...or do you think I busted the caliper? Theres no fluid leaking from what i can see, i hear no leaks when the pedal is pressed, and the fluid level of the system is fine.....this happened once before but the pedal stayed at its normal pressure.
1996 LX, Disc brakes
Awaiting new rotors in mail....
