Hello everyone. I'm new here but I am trying to fix my girlfriends taurus. It is a 2002 3.0 dohc. It has been getting a code I believe it was p0136, I know it said bank one sensor two. Anyway I think I am working on the right one, firewall side after the cat. I got it broke loose with a wrench but after a few turns it seems to be stuck on a bracket. Is there a special wrench to use because I can't see an 02 socket fitting on there. And do you have to remove anything else or is it possible to get it out with everything in place? I plan to get a manual as soon as I can since we will have the car awhile but I am hoping someone can give me a little insite so I can get this done. Thanks
+1 ^
Since it is loose already, can you use an open end wrench?
When you put in a new one, lube connector pins.
