So I changed the t-stat and put a new cap on. The temp gauge STILL is swaying although not as wildly. The recovery bottle is still not hot but kinda warm. Restricted radiator? System hold pressure.
What brand thermostat did you use? I would suspect that the radiator may be plugged, or that air may be trapped in the system. You could also have a weak water pump.
