Okay car buffs with a little knowledge. I bought an 01 Taurus on Saturday (mostly for my 3 month olds stuff!). I bought it with it written into the deal that they would fix the squeel; but I'd like to have some clue as to what it is before I take it in.
It makes the noise all the time; even after warming up. I know it's not the belt for sure. I am thinking it may be the water pump; partially because of the slight coolant smell (weep hole leak smell). I am fairly sure it's not the tensioner because when I press on the belt it is tight but not too tight. So maybe it's just water pump bearing noise? Or maybe the dreaded idler pulley or even belt tensioner. I don't think it's the alternator- no light on.
Any ideas?
Thanks so very much,
Tina
does it sound like metal on metal contact?? Does it go away for a little bit then when its idling it comes back??
If so - one of your pullies is going bad. I have this problem on my car now. Why don't you take the belt off and check all the pullies and pumps?
Does the noise go away after you get above 300-3500 rpms?? Mine did the same thing a few weeks ago. It was the Idler and the tensioner that were fouled up. Try your best in diagnosing it, and good luck my friend.
Thanks everyone. I just traded my 94 Saturn in for this car. That one had almost 120k on it and in the past 6 months I had replaced the water pump, the idler pulley, the belt tensioner, and the alternator. So, basically everything with a pulley on it excluding the p/s pump. The noise doesn't go away and I am starting to think that maybe the tension may be a little too tight and that's what caused the problem.
I would be bringing it into the shop tonight to pop off the belt if I didn't have to take my daughter to the ER after work for an ear infection (fever of 104F- yuck).
The noise is not too too loud and they are fixing it in a week; just I would feel better knowing what it is before I walk in. I work for a dealership (in the same family of dealers) and I know how shady we can sometimes be. Not so much on my end (parts); but sales and service can sometimes get down and dirty!
Thanks again and I will hopefully be able to get Betsy-also in the shop here tomorrow to look at her.
Tina
