Item Purchased: 18" Voxx Rims/Tires
Date Purchased: March 2004
Experience: Negative
Shipping: None
Comments: The transaction failed because the seller did not arrive at the meeting spot. It was later found that the seller had sent a message a few hours prior which was not received before I traveled 5 hours to purchased them.
Because you had my phone numer and should have called (in my opinion). You also did not answer your phone, which you said you had on you at all times. You have also not made ANY attempts to make things right.
Even if I had not come down there, you backed out of the deal. This forum is to let others know of possible trouble in buying from antoher member....that is the reason for my post.
This is not personal, Id like to get along with you still. All the same, the post will stay.
Brad
