Hi all.
First just wanted to say that this is a great forum. I've been visiting for sometime now and found many answers I was looking for. Now it's time to ask some questions to the experts.
My car is 1990 Taurus GL SW, with a 3.0L Vulcan. My great aunt was the first owner and I bought it from her in 1998. It has now 97K miles. I recently did some badly needed maintenance: replaced plugs, wire, cap and rotor, thermostat plus cleaning the throttle plate and IAC.
Ok, this is my case. Since 2000, the fuel pump has been making this humming sound. I've read a lot about noisy Ford fuel pumps, so I assume I just ended up with one of them.
But then I read that a stuck-closed fuel pressure regulator could make the pump noisy by increasing the fuel pressure and making the pump work harder. So I did an experiment an removed the vacuum line from the regulator (which I believe would re-create a WOT condition) and the humming is gone, although I was expecting it to either remain the same or probably increase. Does this make sense to you guys? It seems to me the regulator is not doing what is supposed to but before I go ahead and buy a new one I wanted to get some other opinions..
Thanks in advance for your help. I have also another problem with a code 72 but I'll be checking the vaccum lines and MAP before I bug you about that.
Dave
Dave
