I have an 03 taurus ses.i lost the ability to use turn signals, so to check relay status I turned on hazards. now the hazards,turn signals,power windows, locks, radio, dome light,moonroof, wipers and speedometer do not work. when I turn car off,(with the door closed, key out of ignition and hazards on) all of the accessories flicker randomly. any possible suggestions. I checked all fuses and relays, all are good. please help
My first impression is a bad ground in the body wiring harness.
Probably a ground strap under the dash that is loosing it's 'connection' to the metal it is bolted to.
I would suspect somewhere where it could be subject to moisture, like under the carpet in a low spot.
The wire harness authorities here will have to direct you to the specific locations.
It could very possibly be your TRS (transmission range sensor) switch. Check the post in the Topic Finder and see if it relates to your problem. Symptoms sound the same....
