my parking lights dash lights and taillights went out yday i looked up on here to troubleshoot and solve i've checked all fuses, all fuses are good what can simply be the problem someone help!!!!!!!!!!!
How many grounding points in the lighting system? Where are they?Sounds like a bad ground to me.
Is it your headlamps, or the daytime running lights that won't turn off?What did you find out? I have the same problem with a 1999 Taurus SE Duratec - no tail lights, no dash lights and the headlamps won't turn off until I pull the fuse.
